I am about to attempt a auto to manual swap, the only grey area being the wiring. I understand that I will need a manual transmission harness, do I also need to replace the body and engine harness to a manual 300zx? I assume probably the body harness as the manual 300zx body harness plugs into the clutch pedal switch? Also how does the key lock wire up? Would a manual 300zx body harness fix any issues?
Any other electrical issues I should be aware of?
Auto to manual swap wiring questions - VERTTZ20:08:40 03/20/14
